I don't know why, but the grand master doesn't work with the intensity of my 2 moving head.
I think it's a little bug, because when I try to ad another fixture of the same moving head, the grand master work with the intensity of the new one.
Anyone can help me??
Thanks a lot.
Grand master doesn't work with my Beam moving head
1. most probably the problem is that your Dimmer channel effective range is 131-255 try to change grandmaster mode in VC properties whether it would help.
2. you don't need to create heads if there's only one - try to delete the head definition, maybe it would help
3. you have typo in St(r)obe channel name
- Real Name: Jérôme
Hi
1. It's not the problem, if you download my previous version (qlc plus 3.9), you can see the Dimmer channel effective range is already 131-255, and Grand Master work :/
I try 1 to 255 (in 4.1 version) but it's the same problem.
I also try to modify grand master mode (intensity-->all the chanel), and that work but this is not what I want because the shutter is modified too.
2. Sorry but I don't undersant what you explain to me
3. Yes, thank you
3. Yes, thank you
2. http://qlcplus.org/docs/modeeditor.html You don't have to add all channels to HEAD tab. If there's only one head, you can leave the tab empty (no head -> one head with all channels).
