Hi, ..
on my fedora 24 systems, I get:
sudo dnf install qlcplus-qt4
Last metadata expiration check: 1:22:36 ago on Sat May 20 01:23:43 2017.
Error: nothing provides libqt4 >= 4.6 needed by qlcplus-qt4-4.10.5b-7.1.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages)
Acording to this page https://www.rpmfind.net/linux/RPM/fedor ... .i686.html
.. the package qt does not provide libqt4,
Is this just a simple packaging/naming issue eventually?
Thank you for your work, and your help.
fedora installation fails
Have you tried with the qt5 package ?
I think qt4 is going to disappear from modern distro repositories
