Ubuntu 16.04 with qlcplus-qt5
wkgn
Real Name: Wolfgang Keusgen
Hi Massimo
Thanks to you and your Team for the great Software. I'm using the raspberry version, the windows version and also the ubuntu version. After updating a laptop to Ubuntu 16.04. with the package qlcplus-qt5 ( openSUSE from QLCPLUS download link) I realized that sound to light is not working, I've tried the same package on a different ubuntu 16.04 machine with same result. Both ubuntu machines are only showing the default audio device and not the actual sound cards.
After removing of qlcplus-qt5 and installation of qlcplus-qt4, sound to light is working fine. Since I didn't found a hint regarding this restriction within the forum, I'm wondering, if you are aware of this?
Hey,
maybe you need to install some additional packages: viewtopic.php?f=5&t=9331&p=41079#p41129
Regards,
wkgn
Hi, thanks for support!
After installing the additional package, I have all audio cards and also the alsa_output and alsa_input devices visible available. Sonud to light is working now with qlcplus-qt5!
Regards
Wolfgang
