The USB-DMX-interface is working fine until the channel 11 gets used. Then the complete DMX output is scrambled. I need to quit QLC+ and unplug and replug the NanoDMX cable. After I restart QLC+ then, it works again.
If I start QLC+ on the command line like this:
qlcplus -d 0 -g
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "lightmaXX Platinum CLS-1"
"/usr/share/qlcplus/fixtures/lightmaXX-Platinum-CLS-1.qxf" not in FixturesMap.xml
void IOPluginCache::load(const QDir&) "libolaio.so" doesn't contain an I/O plugin: "Cannot load library /usr/lib/x86_64-linux-gnu/qt4/plugins/qlcplus/libolaio.so: (libolaserver.so.0: cannot open shared object file: No such file or directory)"
DecoderMAD: cannot initialize. Source file doesn't exist.
virtual bool NanoDMX::open(quint32, bool) "NanoDMX Interface" Initialization failed
