I don't understand why you're asking to do this test again: the names were the same in both the cases but only with the second order the result was wrong, so it's not related to the names.
But I did, here the picture and I confirm the same wrong beheaviour.
remap fixture is still not reliable
Sorry if my request bothered you
Should be fixed now on GIT.
Please test and report if it's fixed for you as well.
hey Massimo,
just a question within the occasion, what about the SoftpatchEditor proposed by Offtools?
Actually, the idea of working with the "original" internal channels despite of the venue it's interesting because you don't have to change how you're refer to each fixtures, venue after venue.
I do work in this way too with other software, because the most common issue during a theatre tour it's that often it's not possible to respect the original wiring, so the least that can happen it's that fixtures that originally were plugged together are now plugged individually, and sometimes vice-versa as well.
Fixture groups remapping added on GIT
