Sagitter Slimpar 18
volmar
Real Name: Daniele
Hi everyone,
I just wanted to share a fixture definition, I hope it is everything all right!
Product: http://www.sagitter.com/index.php?route ... t_id=17000
User manual: http://www.sagitter.com/image/data/sagi ... MPAR18.pdf (it is in italian language but I tried to translate the modes for the definition).
Sagitter-Slimpar-18mk2.qxf
(3.75 KiB) Downloaded 66 times
manueldalbo
Hi tankyou!
InterFace
Real Name: Charlee
Thanks for the info
sbobet login
volmar
Real Name: Daniele
the user manueldalbo fixed some issues with the 2d preview, can you integrate this in the next build?
Now should be ok
Sagitter-Slimpar-18mk3.qxf
(3.86 KiB) Downloaded 29 times
Strobe channel range 1-11 should be 0-11.
Fixed and updated the one in the library, thanks
volmar
Real Name: Daniele
mcallegari wrote:Strobe channel range 1-11 should be 0-11.
I think that was the problem. Setting the range 0-11 makes the fixture strobe on the 2D preview while the shutter is "open" (open... it's a RGB fixture...).
