Hi everyone,
I just wanted to share a fixture definition, I hope it is everything all right!
Product: http://www.sagitter.com/index.php?route ... t_id=17000
User manual: http://www.sagitter.com/image/data/sagi ... MPAR18.pdf (it is in italian language but I tried to translate the modes for the definition).
Sagitter Slimpar 18
- Real Name: Daniele
- Sagitter-Slimpar-18mk2.qxf
- (3.75 KiB) Downloaded 66 times
- Real Name: Charlee
Thanks for the info
sbobet login
sbobet login
the user manueldalbo fixed some issues with the 2d preview, can you integrate this in the next build?
Now should be ok
Now should be ok
- Sagitter-Slimpar-18mk3.qxf
- (3.86 KiB) Downloaded 29 times
Strobe channel range 1-11 should be 0-11.
Fixed and updated the one in the library, thanks
I think that was the problem. Setting the range 0-11 makes the fixture strobe on the 2D preview while the shutter is "open" (open... it's a RGB fixture...).mcallegari wrote:Strobe channel range 1-11 should be 0-11.
