Contest LedColor
Nicolas K
this is a fixture for the contest LedColor Blinder.
It has 3 DMX Modes (2, 4 and 5 chanels).
Contest-LedColor.qxf
(2.91 KiB) Downloaded 50 times
Massimo Callegari
Hi, can you please fill the physical information for each mode ?
Thanks !
Nicolas K
I have updated the fixture def with physical information I found on the user manual.
One question about physical information: why are they linked with the dmx mode and not with general information ?
In fixture I make they are always the same (3 pin connector, lamp type, etc).
Wouldn't be a better way to put these info on the general tab ?
Nicolas
Massimo Callegari
Hi Nicolas, yes that is a point already discussed in this forum.
As far as I know, there are fixtures that change physical dimensions on different modes.
Although in general, they are always the same. Probably one day I'll add an option to make them common for every mode.
Thanks for now !
