Martin Mac 2000 Profile
lcslouis
i have created a profile for the martin mac 2000 profile 16bit and 8bit modes i have also attached the gobos since they were not in q
Martin-Mac-2000-Profile.qxf
(18.63 KiB) Downloaded 65 times
Martin.zip
(406.64 KiB) Downloaded 65 times
Massimo Callegari
Do you have the approval from Martin to use their gobo pictures ?
lcslouis
Pictures did not come from Martin I found pictures of the gobo wheels and then used fireworks to make pngs
Jano Svitok
If this is the manual:
http://www.martin.com/service/downloadf ... pdf&cat=65
then some adjustments may be made:
1. tilt range is 267 not 276
2. zoom range is 10 deg to 28 deg
> Sent from sourceforge.net because you indicated interest in
> https://sourceforge.net/p/qlcplus/discussion/fixtures/
> To unsubscribe from further messages, please visit
> https://sourceforge.net/auth/subscriptions/
