ADJ Vizi Beam
Thanks again.
Considerations here too:
- Colour channel. The info 1,2,3,4,... don't help much. Can you please assign a Click & Go color to them ? (if indicated in the manual of course...)
- can you please fill the physical info here too ?
Thanks !
Thanks !
Also, which model of Vizi Beam is this ? 5R ?
If so, it has 2 modes: 10 channels and 12 channels
These are my QLC fixture def's ive been using for a while. I'll go through an update them. Thanks for pointing out what is needed.
Here is the updates I could make from the manual as this is a clients fixture and I don't have one in front of me. White, red, blue, green, purple, yellow and UV colour names were added, the rest are still the useless numbers the manual lists.
all the physical data I could figure out is listed, but wattage is not because believe it or not, the manual doesn't list it! I'll finish the update when I have the fixture in front of me again.
- American-DJ-Vizi-Beam.qxf
- (7.01 KiB) Downloaded 81 times
Thanks for the update. I've added the fixture to QLC+.
I assumed this is the 5R model since you haven't answered my question.
Also, I found and fixed a lot of typos.
