A quick definition I threw together for the Chauvet 4Play (and 4Play CL) fixture. I also took some quick snaps of the various lighting configurations which I'll include in a separate file. You should be able to unzip the gobos into your global/system gobos directory and have the fixture pick them up.
[Product Page](http://www.chauvetlighting.com/4play.html)
[Manual](http://www.chauvetlighting.com/products ... ev3_WO.pdf)
Chauvet 4Play
- 4playgobos.zip
- (11.65 KiB) Downloaded 83 times
- Chauvet-4Play.qxf
- (2.5 KiB) Downloaded 82 times
Hi, thanks for this, but unfortunately I cannot add it mostly because physical dimensions are missing.
Also, I cannot introduce new gobo pictures unless you have a written permission from Chauvet to use them
I have attached my QLC+ fixture definition for the Chauvet COLORdash Batten. Information for all modes taken directly from manufacturers PDF manual.
I would have started my own thread but I couldn't figure out how to attach a file unless I was replying to an existing thread.
- Chauvet-COLORdash-Batten.qxf
- (2.46 KiB) Downloaded 84 times
Hello Kurt. Seems like Sourceforge has this bug since months now. A dirty workaround is to post a new message and then edit it (or reply to your post) so you can attach a file.
By the way I had a look at the colordash and it's wrong.
Physical dimensions are missing again and all the RGB channels are Colour channels instead of Intensity->Red, Intensity->Green, Intensity->Blue.
Can you please fix it ? (also the 4Play would be great)
Then I would be happy to add them both
Thanks !
Thanks !
Sure thing, I've attached an updated qxf below.
I understand what you're saying about not being able to distribute gobos. These aren't pictures of gobos per se, they're just snapshots of the LEDs themselves for the various presets. But I can see why you'd want to err on the side of caution in this case. I guess at least people can download them from here if they're really sick of not knowing what various presets look like (Chauvet's naming isn't very descriptive).
