I'm starting to build a fixture profile for this pretty amazing light bar that I get to work with next week. One of the best parts is the pixel mapping and each LED is individually controllable (up to 24). For simplicity sake, I'll probably run them in groups of 4 (6 sections) or in skp3 mode. The issue I'm having is getting QLC to recognize each pixel group when building effects. Currently it's only seeing the fixtures as a single fixture instead of as 4 "separate" lights. I've attached the manual and the profile I've started to build. Any insight would be much appreciated!
http://www.chroma-q.com/support/manuals ... Manual.pdf
thanks!
jaymez
Chroma-Q Color Force II 72
You have to define 'heads' in your fixture profile.
With this QLC+ knows that the unit has multiple light sources.
See http://qlcplus.org/docs/headeditor.html
