I'm sure this is a stupid question but...
iamwally
Real Name: John Maugeri
I'm sure this is a stupid question but I just want to make sure. Is there no fixture definition for the Chauvet Colorstrip because the settings are the same as the Colorstrip Mini so you don't need separate definitions?
Thanks,
iamwally
jrj12591
Real Name: Jason R Johnston
You are correct the Channels are the same. What i ended up doing was making a copy of the Color Strip mini profile and renaming it just the Color Strip so i could differentiate between the two because i use 2 Color Strips and 3 mini in my setup.
Jason
