Cameo-CLPIXBAR200PRO-CLPIXBAR300PRO-CLPIXBAR400PRO
stelianc
Real Name: Stelian Cunitchi
Hello, use, I hope is ok.
Cameo-CLPIXBAR200PRO-CLPIXBAR300PRO-CLPIXBAR400PRO.qxf
(28.04 KiB) Downloaded 40 times
This isn't right ...
1) The 200 is RBG where the 300 & 400 are RGBW so (without looking to the definition itself) I already can imagine that channels won't be correct.
2) It's better to make copies of the definition and use them on a 1 to 1 basis ... so in your case 3 definition files for the 3 fixture types.
3) the 200 has 12 heads, the 300 has 6 heads and the 400 has 12 heads. -> RGB matrixes f.i. won't work correctly
Please review
Fixture validator found 52 errors. Not bad...
stelianc
I have cameo-clpixbar400pro, but user manual is for all bar, error corrected for 400pro one file, sorry.
Cameo-CLPIXBAR400PRO.qxf
(10.36 KiB) Downloaded 32 times
Fixed the mess and created 3 fixtures with all modes
