Pro-Lights PIXIEWASH
tolmino
Real Name: Tolmino Muccitelli
hi, i have write that fixture
only a doubt....
in 16CH mode, the channel 14 works in 4 different ways depending from channel 13 value
so i have inserted 4 different 16CH mode
Pro-Lights-PIXIEWASH.qxf
(10.25 KiB) Downloaded 116 times
tolmino
tolmino
Excuse me....
i have Validate it
(10.24 KiB) Downloaded 34 times
Added, with a few changes, thanks.
Channel dependency has always been problematic. In this case, I have somehow solved by taking the richer channel (continuous) as channel 14, and specifying on channel 13 what channel 14 does the best way I could.
Should be clear enough for someone using this fixture.
tolmino
ok thanks
nice solution.
