cameo hydra-beam 400wrgbw 6ch mode
- andres robles
- Real Name: Andres Robles
work fine
- cameo-hydra-beam-400wrgbw.qxf
- 6ch mode
- (3.08 KiB) Downloaded 52 times
- andres robles
Hi, in the menu of the device there are 2 options for dmx address, D001 for x channels, and A001 for y channels, specifications are in the accompanying manual
- cameo-hydrabeam-400-rgbw-bedienungsanleitung.pdf
- (1.17 MiB) Downloaded 47 times
Another horrible definition.
Took me an awful amount of time to fix it. Basically I've almost rewritten it from scratch.
PLEASE do not invent things. Use your keyboard SHIFT key sometimes. Stick to the manual. Complete every channel mode, including physical dimensions.
Attached how the fixture should have been
- Cameo-Hydrabeam-400-Series.qxf
- (25.28 KiB) Downloaded 49 times
- andres robles
excuse me. Many of the fixture definition that I share are created the same day that I encounter the fixture and the concert and I only create them to work in that concert, I only share them if someone serves as a quick solution, Create them with more detail and precision ...
