Bug in fixture validator
doughadfield
Real Name: Doug Hadfield
Post by doughadfield » Sat Nov 11, 2017 2:34 am
Hi wonderful people, I have a fixture definition which I wanted to post on this forum, so I've been trying to run it through the fixture validator. However, the strobe channel keeps generating an error. If I set the channel as "speed" the validator errors telling me it needs to be "Shutter". However if I set it to "shutter" it errors telling me it needs to be set to "speed". So whatever I do it won't validate. I attach the definition here. Can someone let me know whether I'm doing something wrong, or if it's the validator itself that's at fault.
thanks and regards
Doug
Uking-LED-Par-36W-18LED.qxf
(2.42 KiB) Downloaded 4 times
edogawa
Real Name: Edgar Aichinger
Re: Bug in fixture validator
Post by edogawa » Sat Nov 11, 2017 3:48 pm
Hi Doug,
it seems that the validator makes that proposal based on keywords it finds in the channel name, and in this case gets confused by two contradicting keywords. I don't know whether the validator's source code is in github or otherwise available somewhere online, anyways I renamed it to just be "Strobe" and now it validates while being a shutter channel.
This sort of contradicts the guideline where you are supposed to stick with parameter naming from the devices' manual as close as possible... but maybe it is the best possible way to handle that, currently?
Ciao, Edgar
doughadfield
Post by doughadfield » Mon Nov 13, 2017 11:49 am
Thanks a lot for your reply and your help, Edgar. I'll make the change this end, and bear your advice in mind :-)
Doug
floEdelmann
Real Name: Flo Edelmann
Post by floEdelmann » Sat Nov 18, 2017 3:50 pm
The validator source code is available on GitHub, but buried deep in an issue's comment:
github.com/mcallegari/qlcplus/issues/963#issuecomment-297451371
Certvalue111
Real Name: certvalue
Post by Certvalue111 » Fri Jan 12, 2018 5:17 am
hello.. I also noticed a bug in fixture validator as well..thanks for letting us know Doug.... much appreciated :)
