Listen on multiple midi channel
titigab
Real Name: Etienne
Hello, first thank you for your awesome work,
I'm an user of the iControls Pro. By default the faders and buttons are mapped on different midi channels. QLC+ force to choose one channel to work with.
I also use whitecat for traditional light cues and it listen on every midi channel.
As the iMap software for remapping is a real pain to use, maybe the ability to listen on multiple midi channel could be a plus for QLC+ ;-)
Thanks again and see you.
this is already possible, have a look at the MIDI in/out plugin: http://www.qlcplus.org/docs/midiplugin.html
titigab
Real Name: Etienne
Thank you,
The setting was a bit hidden in windows, as I had to go down under channel 1 for the special 1-16 to appear. Maybe a selection list would be clearer than a more/less number input field ? Is it the same in Linux ?
Cheers
