Chauvet Geyser RGB
- Real Name: Ronald
Im new to DMX. I got all my lights to work and the Gyser lights to work. I can set off the smoke on the Gyser manually. but When i put it in to a scene and play it back in the scene or show the smoke works but keeps on going and I have to turn off the machine to stop it. How do I adjust the time for the smoke duration?
- Real Name: Andy Arthur
i have the same question but for a chauvet 1800 it works but will not turn off by the button
- Real Name: Matthew Greathouse
Research HTP vs LTP . I believe the default of the Geyser smoke channel is an LTP channel. If you do not give it a zero value after giving it the higher, the latest value it gets takes precedence and will continue to run. You can change it to HTP if you are using it how I think you are.
http://qlcplus.org/docs/concept.html
