Just had a read through again, Im not sure how you derived these particular commands. /ch/01/mix/06 wont do anything as its not the full command. The Xair has 10 mix busses available, 1-6 are busses that are normally assigned to the 6 XLR aux outs on the front (monitors), mix 7-10 are the mono sends for the fx buses.mcallegari wrote:And here's the profile !
I've added all 16 channels, either /.../mix/06 and /.../mix/fader. Also /rtn/aux is there.
Don't know what mix/06 means, but if you used it then I guess it's some sort of level control.
The command /ch/01/mix/06/level would let you adjust the amount of channel 1 going to mix (monitor) 6.
/rtn/aux/mix/fader is used for the stereo channels 17-18, its not a mix bus. (Imagine it being called /ch/17/mix/fader)
Hope this helps.
