Hi, this time I'm gonna be the one asking a question to you.
While developing the QLC+ 5 EFX editor, I thought about the meaning of X/Y offsets when "relative" is enabled.
Do you usually leave them to 127/127 or do you have the need to change them ?
If so, what is the usage case of having specific X/Y offsets in relative mode ?
My idea, to simplify things, is to disable those 2 values when relative is checked.
Relative EFX, how do you use them ?
I keep mine at 127/127.
If you want to effectuate a fan-efx then applying offset (or limits) per fixture is the easiest way of doing that.
Say you have 6 heads hanging at the backdrop symmetrical position in width 1 - 2- 3 - 4 - 5 - 6
Say you want to make a horizontal cross sweep over the stage.
1 will need an X offset (or limit) of 0 to 60
2: 0 to 40
3 and 4: -30 to 30
5: -40 to 0
6: -60 to 0
start the efx with a fade-in set to the same speed of the efx itself and you get a wonderful fanning / sweeping effect on stage.
(if you'd apply -on top of that- an sine on the Y-axes limiting or offsetting per fixture you'd end up with a 3D fanning / sweeping effect)
my 2 cts
2: 0 to 40
3 and 4: -30 to 30
5: -40 to 0
6: -60 to 0
my 2 cts
@GGGss I think you didn't get my question
I'm talking about X/Y offsets in the Movement tab. Not the -per fixture- start degrees.
When the "relative" checkbox is checked, I don't see a need to customize the offsets, unless someone come up with a specific usage case that requires it.
Stupid me - was looking at the XY-pad
and no - in relative mode you don't need the offset - you easily can change the base-position on which the relative part is added on to.
Sorry for your time I've taken
