Hello Forum,
my 4 LED-Bars have 8 RGB Lights. I placed them to an rectangle. Now i made 32 Scenes: on Scene one only red from Channel one is on. On Scene two only red from Channel two is on. And so on. Then programmed an Chaser with this Scenes. All works as expected with red Color. Now the question:
How can i easily control the Color?
Max
Rotation Effekt with LED-Bars
First: make sure that in the definition file every RGB-source inside your fixture is defined as a head. Then put the heads of your fixtures inside a Fixture group (make it 8x8 pixels square to reflect the real position).
Then: goto RGB matrixes and add the Fixture group and start playing around
Try it - you don't have to program 32 scenes for 1 color... with some mouse clicks you'll be playing ping-pong, reverse circkles, random stuff, ... in all the colors you want (even dynamic rainbows)
