Capture QLC+ Output
jdwyatt
Hi All,
I was wondering if there was a way to capture the output of a programmed sequence from QLC+ and store onto a raspi for replay (so the Protobox can run standalone)? I've been playing with the ola_recorder command line tool so I may be onto the right track. Any other better ideas for a robust solution? Eventually, I'd like to set it so that the Protobox will fire off saved sequences when it receives telnet commands.
Diagram of my System:
Just use QLC+ on the Raspberry Pi and load the same project programmed on a PC
jdwyatt
Good call, that wasn't too hard! Anyway to get Virtual Console buttons to trigger via telnet commands?
You can trigger virtual console widgets using one of the supported input plugins: MIDI, OSC, ArtNet, E1.31, GPIO, etc.
Why do you guys always want something that is not there ? Why telnet anyway... :confounded:
jdwyatt
:mrgreen: Sorry, in my neck of woods (digital cinema) most devices communicate via telnet strings and sometimes GPIO. I'll see what I can come up with for a workaround.
