Hello.
I found some bugs while using the program.
When I find scene, which I made, at "Show" menu and "Chaser" menu, no scene is in the list.
For instance, I made the scene "ch3, ch5" which you can see in the picture,
no scene is in the list when I find them at "Show" menu and "Chaser" menu.
Also, when it happens, soon the programs are turned off.
This often happens, help.
No scene is in the list when I find them at "Show" menu and "Chaser" menu.
please post:
- exact QLC+ version
- operating system
- qxw file and all needed custom qxf files (so that we can open the workspace)
- exact steps how to reproduce the problem (i.e. how did you create those functions)
please post:
- operating system
- Real Name: kim kh
I'm not used to english, my expression would be awkward
However i have try as i can do best added relation picture
Under the process below, program turns off and some 'scene' deleted automatically with error.
Case1; set the light of "CH1" 'fade in' (picture1) Case2; set the light of "CH2" 'fade in' (picture2) Case3; control brightness same as the complete statement of 'fade in' of "CH1", "CH2" (picture3)
continue....
continue....
- Real Name: kim kh
The text below is about the version and system.
# qlc version : 4.11.0
# System
Mac Pro (late 2013)
OS X El capitan 10.11.2(15C50)
3.7 GHz Quad-Core Intel Xeon E5
12GB 1866 MHz DDR3 ECC
AMD FirePro D300 2048 MB
And i upload qxw file
Thank you
# System
Mac Pro (late 2013)
Thank you
- zzaptoong test 0906.qxw
- (9.96 KiB) Downloaded 38 times
- Real Name: Mark Lohrey
Hi zzaptoong,
I haven't been able to reproduce your error, but setting sequence lengths to infinite for shows used to cause crashes and of course, it doesn't make much sense for shows to have infinite holds. Just set them to the length of the show if you want them run for the whole show.
Also, on another mac related note, you can capture the screen quite easily using the 'grab' app or keyboard shortcuts (shift-cmd-3 etc)
Cheers
Mark
Cheers
Mark
