Speed Dial Question
yokosuna
Hello out there,
I am not able to understand the behaviour of the speed dial in a my case:
Whenever I start a function through a button, the attached speed dial works
as expected a changes the speed immediately.
But when I start the sane function through the XY - widget, the speed dial
change has no effekt. Furthermore, I can start the same function twice,
with the button and with the widged with surprising effects.
Apperently the function is running two times and perhaps intended.
Can someone please explain ? Thank you.
SpeedDialProblem.qxw
(4.41 KiB) Downloaded 23 times
Duplicate of
viewtopic.php?t=9535
The issue has been fixed and if you use Windows, you can check the Windows test version 4.11.1.89
yokosuna
Thx allot ! Just wanted to say that
4.11.1.89 fixed the problem, 4.11.1.90 reintroduced it...
Yoko
That's because 89 is taken from an experimental branch, while 90 (and above) is taken from the main sources branch
