Hi All,
Is there any way to have a flash button over write a toggle button. This is what I'd like to achieve: I have a toggle button that sets all my lights to blue and then I have flash buttons that allow me to temporarily flash different groups of lights to red. Any idea how I could achieve this?
Kind regards,
Ethan Benjamin
Flash Over Writes Toggle
- Real Name: Lukas
Hey,
I don't think this is possible at the moment. You could use loopback, trigger some action to activate a scene and additionally disable the blue scene button. The problem is, this will not activate the blue scene again afterwards.
Regards,
Regards,
- Real Name: Lukas
Well I need to correct myself: This is not possible with HTP. You could try using LTP - this has some other major implications, like you need to include other fixtures you want to switch off during flashing. I tried to give a basic example in the attached workspace. Try experimenting and maybe find a suitable solution for you.
- flash overwrite.qxw
- (3.77 KiB) Downloaded 51 times
I´m using this on a regular base: running basic functions and do some
overrides from time to time - works like a charme but be sure to set all
fixture channels to LTP
- LTP Sample.qxw
- (2.91 KiB) Downloaded 49 times
