Multi page
simonegr
Real Name: Grigis Simone
Dear friend's
I have create a multi page frame, and inside i have put 2 the frame exclusive in th first page and the slider in the 2 page, and i have this problem:
- when i launch the console and i use the first page i dont have a problem, but i chance in the second page the slider it's ok but when i return i the fist page the button it's no work .
Can you help me please ?
janosvitok
Real Name: Jano Svitok
Please attach your workspace file (.qxw) and any custom fixture definitions (.qxf).
simonegr
In attached i send the worksspace and the fixture
Thanck you very much for the help
Spettacolo Cinema Stella Alpina Selvino.qxw
(52.92 KiB) Downloaded 35 times
LED-PAR-RGBWA+UV-10CH.qxf
(2.76 KiB) Downloaded 29 times
Proel-Fog.qxf
(854 Bytes) Downloaded 29 times
Hey,
I tried you workspace and was not able to reproduce what I got from your description. I assume step by step it would require these things to do:
  1. Try page 1 (works as expected)
  2. Go to page 2, try the slider (works as expected)
  3. Go to page 1, try it again (does not work as expected)
Did I got it right?
Please also state your QLC+ version.
[EDIT] As a side note I noticed a bug when opening your workspace with the latest source code, I already provided a PR which fixes this. Anyway, I don't think this is related to the issue described above.
simonegr
Yes it's correct.
I have re-installed the qlc in the last version (but it's the same that i have), but i have the problem.
I dont understand that it's happen. It's Windows 10 ?
Simone
simonegr
I have create a new workspace with a multipage frame, the problem it's only if i put the another frame in the principal multi page
simonegr wrote: Sat May 27, 2017 10:07 am I have re-installed the qlc in the last version
Which one? (version number)
Can you try a test version?
simonegr
I have installed the qlc test versione 4.11.0 GIT and this it's ok
Thank's
