Hello I'm new to this Forum and QLC+
I have tried to setup an Audio triggered cue list as described by DJ Drew
but I can't get my list to trigger ie change to the next scene. The list remains stuck.
I notice movement on the EQ of the Audio trigger but no movement of the cue list.
The Chase associated with the cue list works fine when run from the function window and common hold is set to anything other than infinite.
I am using Mac Book El Captian with QLC+ 4.10.5b have also tried it with QLC+ 4.8.5 but no success with either.
Can anyone help
Audio triggered cue list (DJ Drew)
Can you attach your qxw (workspace) file and any custom fixture definitions (.qxf)?
- Real Name: B Sirie
Workspace file attached, used with generic RGB definition.
- Chase workspace 01.qxw
- Uses generic Dimmer RGB
- (2.22 KiB) Downloaded 43 times
Hi did you make any progress with the audio triggerjanosvitok wrote: ↑Wed May 24, 2017 9:26 am Can you attach your qxw (workspace) file and any custom fixture definitions (.qxf)?
I don't see any Cue List nor Audio Trigger in the Virtual Console. Please attach proper file.
Ok thanks for your help.
I've created another workspace please find it attached.
- Test 01.qxw
- RGB Audio trigger
- (3.47 KiB) Downloaded 54 times
Much better. Did you try to lower the thresholds?
Other than that, it looks ok. I don't see anything wrong.
