Button not responding to midi messages
Ariajazz
Real Name: Julio
Hi again.
QLC is receiving CC midi messages through LOOP BE and MIDI YOKE ports (I tried them both).
1) I send CC49 and QLC receives CC50.
2) Button does not respond to midi message via internal midi ports.
3) Button responds when CC midi message is sent from KORG Nano Kontrol 2 through its physical port.
What is wrong?
Did you use a specific profile?
http://www.qlcplus.org/docs/howto-input-profiles.html
Can you send your profile... possible there is something wrong with it.
As long as QLC does not know what to do with the signal (entering QLC) you cannot set a button to react to the incomming signal...
Ariajazz
Real Name: Julio
Problem solved. Thanks
