Hi Colin,
Sounds like you are having fun finding your preferred work flows.
The intended use of channel groups, I believe, is to allow you to quickly alter a particular channel on multiple fixtures. For example, you create an LED Red group and an LED blue group and an LED Green group etc and then this will allow you to adjust that channel on each fixture.
Referring to your previous post, it is not absolutely necessary to enable all fixture channels. When you copy current values to all fixtures (as per your step 10) then the required channels will be enabled. There are some advantages to not enabling all channels particularly if you have more complex fixtures.
I too have found being able to make quick adjustments during tech rehearsals or dress rehearsals quite a challenge. You might be interested in this very long thread... viewtopic.php?f=18&t=10004 as many of those involved were using QLC+ in theatre type situations. The new 'over-ride' slider is available in the test release section viewtopic.php?f=12&t=3135
I use a mixture of VC DMX dumps and editing scene directly when setting up a show.
Cheers
Mark
Operational Complexity
- Real Name: Colin Brown
Hi Mark
Channel groups do not help me much as I like to have arbitrary sets of fixtures in my groupings. Also when I have several groups in a scene then I need to individually select fixtures to make use of the "copy to all" feature. In many cases I want to pick my colours as well so R, G, B groups do not help there. I simply enable all channels as it is fewer clicks than having to separately enable individual fixtures (I really go for minimum input where possible).
I have just looked at the first link you provided and the very first item mentioned "The Simple Desk is NOT integrated in the VC operating mode and so sort of stands independent of it which makes it difficult to use while running cues in a cue list, etc." is exactly what I have just come across myself (and is probably a show-stopper for me - next show in a few days time).
I can live with the scene setup of RGB fittings as I have outlined but was looking to use Simple Desk for the dozen or so dimmer channels we use for the wash lights. It is so frustrating that I can bring up a scene in VC along with dimmer channels and see the faders where I want them in Simple Desk but cannot record what I see into a cue (not WYSIWYG)! Another pain is that Cues get created with 0 duration. If one wants to manually step through a show then infinite duration is a far more logical default choice in my opinion. It would also be nice to be able to choose a default fade-in/fade-out (ie 2 secs).
Cue-editing channel take-over that requires clicking the X under each red-highlighted channel if one has many active channels is just downright awful (I could live with a master reset).
A pity, I was beginning to like qlcplus too.
Cheers
Colin
Cheers
Colin
- Real Name: Mark Lohrey
Hi Colin,
It is interesting that you are trying to use simple desk to set scenes. I rarely use it for anything except for testing purposes.
I use the widgets in Vitual Console to make an environment that controls the various channels I have. It is incredibly flexible and powerful. You may need to explore some of the options. Also it is possible to dump dmx values into a new or existing scene (remembering that Qlc+ Generally uses HTP intensity channels). I then tweak scenes in the function manager.
I am assuming you have put your scenes into a chaser and then using a cue list in VC?, if so it is possible to select ll the cues at once and give them common fade in times for tweaking later. You can also make them lock to the same timing values.
I would be interested to see you workspace. Would you mind sharing?
Cheers
mark
Cheers
mark
Hi Mark
After playing with qlcplus a little more, I agree that the simple desk seems to be mainly for testing. That said, although qlcplus allows me to do most things I want it does not fit with how we run our shows. You asked for more detail on our "workspace", so here goes:
Most of our shows are community theatre or dance shows and are typically programmed "live" during one or two rehearsals (especially when children are involved) so a scene has to be set up in a minute or so. There are two lighting guys, one using a TheatreLight desk to program up general wash, spots and parcans. The second (me) uses software I developed using a python backend and browser frontend that specifically handles RGB fittings. It is a work-in-progress, I made a few improvements just before this current show. Pre-show, I assign names to fittings as set up in the rig and configure a mimic display to see the DMX output (as jscolor fields in mimic). Scene programming is done from one browser panel. I create or copy to an input name. This brings up the fittings as rows of name, jscolor field and four radio button groups A,B,C,D. All fittings within a group get set to the same colour when a corresponding jscolor field is set. Programming can be selected blind or live. Copying a default scene that just has an often used groupings preset (eg FOH, CYC) can reduce scene setting to a few jscolor selections. Individual fittings can be set if no group is selected. Scenes automatically get appended to the RunTime panel. By default all scenes/chases have a 2 sec fade-in/fade-out but that can be overridden to snap. Chases are programmed by adding 3 digits to the name (step fade-in, duration, fade-out [each in multiples of 50msec]) followed by a comma and the number of steps. Fade-in/fade-out can be selected to be sequential or as a crossfade, so flashy or smoothly varying chases are possible. The grouping buttons set A,B,C,A,B,C,... across the cyc for example allows one to get colours moving across the screen. Typically step 1 colours assigned to A,B,C are assigned to B,C,A on step 2 and so on. Thus left-to-right, right-to-left, front-back chases are easy to set up. Using a single group gives steps of just one colour, two groups gives toggling colours and so on. Colours are arbitrarily chosen from jscolor palette. From experience, I can usually get a chase that matches the mood and tempo of a song or dance.
Independently, I had been toying with setting the lights in a grid (similar to the RGB matrix) but have found that my groups approach to be adequate and a whole lot simpler to implement.
I can think of one change in qcplus that would help me would be a few user-set defaults for chases. For example, when creating a new chaser there could be a couple of selectable user default buttons. That would save me having to select Run Order, FadeInSpeed Common, FadeOutSpeed Common and then after the first step is entered set the FadeIn time, Hold and FadeOut time. I would also like to be able to read in from a DMX device the scene channels from a dimmer board (or alternatively from a file I could programmatically create).
Cheers
Colin
Cheers
Colin
HI Colin,
Your development of your own processes and software is very impressive and really interesting. Thanks for sharing.
I guess when you have done all the programming and customisation it is going to be very familiar to you and much quicker. I must admit, initially I found QLC+ quite slow to work with but once you have a good virtual console set up then it is much easier and quicker to set up a show. I have created one page that basically is set up as a lighting desk and I use that to adjust and then record the scenes. Then when it comes time to run the show, I use another page with cuelists (and the odd button) so I can basically just step through the show. QLC+ has issues when applying fade times to RGB Matrices from within a cuelist so until that is sorted I occasionally need to trigger those events with a button or slider outside the cuelist.
I use many RGB matrix effects. Even with straight dimmers they are useful for quickly creating chases. Now I have enough variations for the dance numbers that I get with Primary School productions, especially if I am making it up live.
For more complex set-ups, especially as I am on my own and rehearsal time is limited, I have taken to recording the dance numbers etc and then building my lighting cues when I have some peace and quiet. I have a 3-d visualiser of our auditorium lighting rig and that can help when programming off line.
For our 'real productions' i spend far more time fiddling cue lists and being precise about light levels and times.
Cheers
Mark
Cheers
Mark
