I cloned a scene containing a sequence expecting to find a copy of the scene inside the sequence contained.
The scene was cloned but the sequence no.
How to clone Function / Sequence
- lorenzoandreani
- Real Name: Lorenzo Andreani
I think this is wrong ... you cannot create sequences inside a scene ... so I don't understand what you try to say?
The only 'clone' possible from within scenes is to add the scene you are working with right now to a new step inside the chaser you selected.
- Real Name: Lukas
From: http://www.qlcplus.org/docs/concept.html (sequence section).A Sequence is bound to one specific Scene, which means that all the steps of the Sequence can only control the enabled channels of that Scene.
I guess you wanted to say: "I cloned a scene containing a sequence expecting to find a copy of the scene containing a copy of the sequence."lorenzoandreani wrote: ↑Sun Apr 09, 2017 9:40 pm I cloned a scene containing a sequence expecting to find a copy of the scene inside the sequence contained.
After working out the definition I can confirm this on Xubuntu 14.04 64Bit Qt5.
I'm not 100% sure if this is really meant to work but I do think so.
- lorenzoandreani
YesI guess you wanted to say: "I cloned a scene containing a sequence expecting to find a copy of the scene containing a copy of the sequence."
