MIDI and Audio Questions
AlanC
Real Name: Alan Chavis
Hello all,
I'm a new QLC+ user and I'm trying to set up a lighting system using QLC+ for my cover band. I have several goals that I'm trying to achieve:
- From power up, the light show is in blackout, but ready to start. I've got a Raspberry Pi that I'm trying to configure to run the show.
- Change Chases via MIDI program change (or some other MIDI value), so each song can have a different chase associated with it. The first time I send a program change, it starts the show.
- Next step in Chase is triggered by audio signal.
So far, I've managed to create a variety of Scenes and Chases. On the virtual console, I've created a cue list for each Chase, and an Audio Trigger for each cue list.
Questions:
1. Do all of the above goals seem like they should be possible to achieve?
2. The Audio Trigger Widget has a green check box on it that must be clicked to enable it. Is there any way to make this active by default? If I'm running the Raspberry Pi headless, I don't want to have to log in to enable these every time.
3. Is there a better way to configure QLC+ to achieve these goals (besides cue lists and audio triggers)?
Thanks for your help!
Alan
AlanC
I think I've figured out the MIDI side of things.
Now I just need to know how to auto-enable the audio triggers.
Could I do that with a script somehow?
Hey,
AlanC wrote:1. Do all of the above goals seem like they should be possible to achieve?
Yes.
AlanC wrote:2. The Audio Trigger Widget has a green check box on it that must be clicked to enable it. Is there any way to make this active by default? If I'm running the Raspberry Pi headless, I don't want to have to log in to enable these every time.
You can assign a loopback channel as an external input to the enable button. Then activate the loopback channel with a script at startup (set it as startup function). You may need especially these links:
http://www.qlcplus.org/docs/tutorial-soundcontrol.html
http://www.qlcplus.org/docs/scripteditor.html
http://www.qlcplus.org/docs/loopbackplugin.html
http://www.qlcplus.org/docs/functionmanager.html
AlanC wrote:3. Is there a better way to configure QLC+ to achieve these goals (besides cue lists and audio triggers)?
For the different chasers for every song maybe give a frame with multiple pages a try: http://www.qlcplus.org/docs/tutorial-multipage.html
