What I'm wanting to do is have 4 gameshow buzzers - we're planning to use the Buzzers from the game Buzz, these can be Midi controlled and so go through to QLC no problem. The issue is that I want to be able to only have one function active, then add a delay before any other function can be activated.
So that if Player One presses their buzzer, then if Player Two presses there's it won't overwrite that first Player's Function - or start Player Two's function, something like a 20 second delay before the next function can be activated, either in that group, or overall.
If this has to be on a completely separate QLC software, that isn't an issue!
If anyone has any suggestions on how to go about creating something like this, I would be most grateful!
Thank in advance,
Sam Brooks - Brzam
One Function at a time, without being able to be interrupted - Quiz Show Buzzers
- Brzam
- Real Name: Sam Brooks
This message was transmitted using 100% recycled electrons.
- Real Name: Lukas
Welcome to the forum!
You could place 4 buttons in a frame that have your buzzers as external input. To each button, you assign a script that activates some scene (as you want to light somebody or whatever you want) and then disables the frame over loopback. After 20s waiting, it enables the frame again.
I made a sample workspace for that with 2 buzzers. For testing purposes, I added two buttons representing the physical buzzers. These are the input to the buttons in the frame via loopback.
If you have further questions, don't hesitate to ask.
Regards,
Regards,
- buzzers.qxw
- (6.79 KiB) Downloaded 88 times
For the novice user, I did some explanation with labels in attached project...
(had to find out the logic for myself also ...)
- buzzers.qxw
- (9.79 KiB) Downloaded 109 times
- Brzam
Thank you both!
These projects are extremely useful and I will use them to build my project, will report back with how it goes!
Thanks again,
Sam Brooks - Brzam
Thanks again,
Sam Brooks - Brzam
