I'm not sure if this is a bug or a usage issue but when I set my show to be BPM 4/4 and turn on snap, the item does snap but seems to land between beats. Screenshot attached. My goal is to create a show that's sync'd to BPM so when we play live the cues synchronize with the music. I could do it by adding up the milliseconds for each measure but that will be time consuming.
On a related note, is there an easy way to create a visual "metronome" in QLC? I want to have a white flash in time with the beat to see if we can play with that instead of an audible metronome.
Thanks,
- ken
Snap in Show Manager
to the visual beat indicator...
create a dummy cue
make a chaser with 4 steps using the dummy cue
use the 'master' beat (see below)
make sure that in the virtual desk the chaser is large enough to show the 4 steps
= here you have your visual metronome (only you to decide which of the steps in the 4th 1/4th in a bar
entry BPM in stead of ms...
no you can't actually but it's easily converted doing some maths (with 4/4 at least)
60/BPM = number of ms per quarter
OR
4*60/BPM = time in s. per bar.
Good luck
create a dummy cue
OR
Good luck
