I have created a fixture with High and Low bytes for the RGB channels. But when I fade between different settings it appears to still just use one channel and do the 8 bit fade. Is this feature implemented? If so can I get some advice on how to set it up? I looked through a bunch of fixture definitions but could not find any example.
Thanks.
16 bit RGB Values
16-bit channels are currently used only for EFX pan/tilt. I am slowly working on it, but I can't promise any time frame.
What model/make is your fixture?
