Hi
I have a Fixture, Robo DJ Scan 150xt.
In some of the Gobo you can control the speed of fx Strobe effect from slow to fast (max 8FPS) by using a Value between 064 and 127 on the Gobo channel, is there a way to control that in QLC+?
Sorry for my bad English I am Danish.
Help to Gobo / Fixture
in virtual show make a slider
set it to level-mode
change the minimum to (064) and maximum to (127) levels
Select the fixture and channel you want to control
there you go
Well documented in : http://www.qlcplus.org/docs/vcslider.html
there you go
