Hi, new here so excuse me if this is in the wrong place.
I've searched and found very little documentation on shortcuts (I saw the few for the Main Window, http://qlcplus.org/docs/mainwindow.html) - but I've mostly just discovered them by guessing.
I've found spacebar will play/pause in show mode, however pause does me no good if I need to go back a second or two and try the cue again. So I must stop, but I can't find a keyboard shortcut for stop, and all this mousing around is driving me crazy!
I was hoping there is a hidden keyboard shortcut for Stop as well as Pause.
Is there one?
[Show Mode] Keyboard Shortcut for Stop?
The stop shortcut was supposed to be CTRL+O but I checked and it didn't work.
I changed it to CTRL+Space and committed the change on GIT.
Since you haven't stated the OS you're using, I cannot direct you to a test version
