control fx speed w slider
Hi everyone weve been using qlc+ in the company i work for for the last two months and the software is incredible, i would like to know if i can change fx time (duration in seconds) with a slider so i can assign it to my midi controller and change the speed, thank you for your time
you need to create speed dial, set it to control efx duration. then set external input for the speed dial - choose the midi fader.
you may control also chasers with the same speed dial. I set speed dial duration to one beat, and efx duration multiplier to 1/4 so that one efx loop takes 4 beats (sometimes 1/8 - two measures for one loop).
