Fixture selection and control
olialonso
Real Name: oli alonso
Hi all.
Is there any way to select a luminaire and have control of its individual parameters, and then select another and so? As a next or previous button to some consoles?
Or any way to select and change parameters fast?
MidCity
I'm pretty new to this forum, so hopefully I'm not pointing you in the wrong direction. If you make a frame in VC, then make widgets for each function of a given fixture you should be able to do this. Copy those widgets to individual pages within the frame you've made you should be able to control them individually in any way you like. You can then dump your new vales to your saved scenes.
Alternatively if you're not dealing with multichannel fixtures simple desk works fairly well for cueing through simple things, and assigning looks to submasters. Also live edit opens up some of that functionality as well. The only problem with live edit and simple desk is it is alot of mose work to get to where you want.
Hope this is helpful
