I wonder if it is possible to run a chaser with a specific scene at its end, which will keep its values even though the chaser stopped.
For example you could create an "animate-in-chaser", which will fade from black to green and then the chaser function stops, but the green scene will still be active...
I hope you understand ^^
Chasers & Scenes
What if you set the last scene duration to infinity?
- Real Name: Jim Ostrosky
I know this is really old, but I don't find any FAQ on this. What was your solution ?
