MAC OS and Enttec OPEN DMX
sergeichevks
Hello!
I am trying to cross a clone Enttec Open USB DMX with QLC + under MacOs. The device is seen in section Input / Output, but in the mode of Open Tx does not want to work.
On Windows and Linux, there is no problem (ie everything works), somebody faced with?
Can it is necessary to put a driver?
I saw somewhere in the program, in this mode, the driver libFTDI, what can it?
QLC+ version 4.10
mlohrey
Real Name: Mark Lohrey
Hi
Check this out: http://www.qlcplus.org/docs/questionsandanswers.html
You will need to disable the apple driver then it should work.
There are a number of theads int the forum addressing this issue.
