Hello.
Have a UDMX device. The problem is that on my laptop with Windows 7 64bit when connected to USB 2.0 not working properly led par function strobe flashes much slower. in USB 3.0 is working properly
On the laptop with windows 10 will not work properly in any USB port
Tried to connect a udmx on UBUNTU, also does not work properly
Further, if you connect such transmitters to the device and the lamp, in any port, everything works correctly.
In the settings input/output
DMX Frame Frequency: 30Hz
System Timer Accuracy: Bad
Sometimes good, but still, isn't working properly.
Tried to add keys to the registry mastertimer and udmx? didn't help
The program freestyler on any system and on any USB port is working correctly, but I don't like freestyler. your program is much more interesting.
