Dear,
i have buy the bcf 2000, but i dont now if it's better use this with makei mode or normal mode ? what'is the difference ?
Best regard's
BCF 2000 usage
http://www.qlcplus.org/docs/supported-i ... vices.html says (I wrote that ) that mackie mode has more controls.
I also wrote in commit that added the profile:
On the other hand, in normal mode you can customize buttons and faders (e.g. whether buttons are toggle or momentary/flash).
Don't forget to set MIDI channel to 1-16 in mackie mode in MIDI plugin settings.
That means (if I remember correctly) that in mackie mode you can use the top right buttons (edit section) as well.In comparison to "normal" mode, all buttons are usable.
Two leftmost encoder groups buttons are shifts.
