Video issue on windows 10 32 bits
alstetatrac
Real Name: Alain Sauvanet
Hi All,
I am using QLC+ for theater management. Release 4.11.00.29 and previous releases.
I tried to display video under windows 10 32 bit release using different formats : mpeg1, mpeg4, mov, etc. without success.
I noticed different behaviors :
1 - The QT player displays a black screen.
2 - QLC+ hangs when trying to leave it (exit) after stopping video display
3 - I tried windowed, full screen without success
4 - I tried to display on primary or seconday display without success.
5 - looking for an answer in the forum I installed the K-Lite code pack basic without any change on QLC+ behavior
I recompiled QLC+ following all the steps explained in building QLC+ on windows using QT5.
The compilation was successfull.
I had to manually copy all run time dll in the c:\qlcplus directory to make it works (release mode).
Video cannot be played testing many formats.
The mp3 is not supported "The audio file cannot be played with QLC+, Soeey"... the same mp3 file was played with the official release.
Question :
Is i spossible to play video file with QLC+ (using QT 5.6.2) under windows 10 x32 ?
Thank you in advance for your support, har work and help.
Best Regards
Alain
alstetatrac
I finally workarounded the problem using scripts and command line.
It works fine in that way.
Regards
Alain
