Could you send me an example of the way you have this done in Node Red?
I use Node Red with MQTT for home automation, but if I can control QLC+ with it, it would be very usefull!
Currently I have made Quizbuttons which works with MQTT and Node Red, but if I can connect these with QLC+, the lights can turn to a certain color when button is pressed.
So all lights are going red when team red pressed the button, blue when team blue pressed etc.
Looking forward!
EDIT1:
Found artnet support in Node Red, soon I will test this!
http://flows.nodered.org/node/node-red-contrib-artnet
