Using External Midi to program
mouzzikos
Real Name: Alkinoos Peratinos
Hello , is it possible to write scenes and chasers ( moving the fixture faders ) using midi controller?
Welcome,
As you are not asking specific questions: Yes you can.
Did you check the tutorial? http://www.qlcplus.org/docs/tutorial-bcf-lc2412.html
Regards,
janosvitok
Real Name: Jano Svitok
If the question is whether faders in Scene Editor are externally controllable then the answer is no.
mouzzikos
Well..sorry for not being so definite , i have an AKAI APC20 , for playback everything on the virtual console. I would like to use this ( or if its possible other methode) , on writing a scene in fuctions tab.
janosvitok
It looks like you may use Channel Groups: http://www.qlcplus.org/docs/channelsgroupeditor.html
I've never used them myself, so I can't comment, but it looks like you can assign external control to them and they work in Function editor.
Check Massimo's tutorial #2: and tutorial #4
