Hello
I have a digital Enlightment USB interface ( fx5) and windows 7 64 Bit and want to Control LED spots an Movingheads with Q light Controller.
in the Q Light Controller at the plugin Page the Plug in is listed, but only as input.
No Output is listed.
When i update the Interface, than a massage came, that i should check if the UDEV RULES are installed.
What is the UDEV Rules and where can i install them ?
Also i have a Eurolite DMX 512 Pro interface, can i use this beause in the list it is only for MAC. ?
udev rules
udev is a linux kernel mechanism to manage devices. https://en.wikipedia.org/wiki/Udev
It's not relevant for windows.
And why can i Only select the input from the Plugin ?
On the Plugin page i can Update the Plugin, but than the massage with die udev rules come.
why comes this massage when i Use Windows ?
if it is not relevant for Windows, why become i the Massage that i should look if the udev rules are installed ?
my other Interface the Eurolite USB Dmx 512 pro can't used, because Q Light Controller suport it only for IOS.
what must i do that i can use my Digital Enlightment Interface ?
1) there's no need to ask 1000 questions when you just need 1
2) do not invent things:
3) I don't have a FX5, so I can't help. It is supposed to be working on Windows because it shares the same code of Linux and macOS.
If it has issues on Windows, then someone with a FX5 and willing to help could provide some details.
If you really want to use the FX5, at the moment you need to use another OS. I suggest Linux
QLC+ doesn't even run on iOS. The Pro model is known to be supported only on Linux, unless someone proves it differently.my other Interface the Eurolite USB Dmx 512 pro can't used, because Q Light Controller suport it only for IOS.
BartM wrote:Why ist the FX5 Interface listed by the supported hardware for Windows, if it don't run ?
mcallegari wrote:3) I don't have a FX5, so I can't help. It is supposed to be working on Windows because it shares the same code of Linux and macOS.
- Real Name: Martin Kurze
I just did a short test with the FX5 and it did work without any problem. I tested 4.10.5 and 4.10.6 GIT on Win7 64 BIT and Win 8.1 64 BIT on different hardware.
Regards Martin
Regards Martin
- Real Name: Peter
I have a similar problem.
Using a DIY FX5, windows 10 64bit and QLC+ 4.10.5b.
I start QLC+ and plug in the FX5. All is working fine until i plug in another USB device.
Then i get the Error Message posted above.
Edit: Tested it with the Nodle U1. Same problem.
Sounds like this is not supported unless you guys provide some details about the device. In particular the USB VID/PID.Using a DIY FX5, windows 10 64bit and QLC+ 4.10.5b.
If they're different from the original FX5, then QLC+ might treat them like a generic HID device, which are normally input only devices
Hi Massimo,
I took a closer look to the FX5. Although the device is operating properly as output and input device, there are differences regarding the used OS. For that reason QLC+ (4.10.5b) is not able to print out the Manufacturer "Digital Enlightenment" with Windows 8.1 64 BIT and Windows 10 64 BIT and also the Product string "USB DMX" is not shown.
With usbtreeview http://www.uwe-sieber.de/usbtreeview_e.html you see some differences in the description of the USB device:
Win 7
and Win 10:
Maybe this helps. Please write if you need further information.
Regards Martin
Win 7
=========================== USB Port4 ===========================
Connection Status : 0x01 (Device is connected)
Port Chain : 1-4
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : USB-Eingabegerät
Device Path : \\?\usb#vid_16c0&pid_088b#0000000010001117#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_16C0&PID_088B\0000000010001117
Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0025 (GUID_DEVCLASS_HIDCLASS)
Driver : C:\Windows\system32\DRIVERS\hidusb.sys (Version: 6.1.7601.17514 Date: 2010-11-20)
Driver Inf : C:\Windows\inf\input.inf
Legacy BusType : PNPBus
Class : HIDClass
Class GUID : {745a17a0-74d3-11d0-b6fe-00a0c90f57da} (GUID_DEVCLASS_HIDCLASS)
Interface GUID : {a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Service : HidUsb
Enumerator : USB
Location Info : Port_#0004.Hub_#0001
Location IDs : PCIROOT(0)#PCI(1C06)#PCI(0000)#USBROOT(0)#USB(4)
Container ID : {a2f5fd47-4b17-5448-858f-930a9191d021}
Manufacturer Info : (Standardsystemgeräte)
Capabilities : 0x94 (Removable, UniqueID, SurpriseRemovalOK)
Problem Code : 0
Power State : D0 (supported: D0, D2, D3, wake from D0, wake from D2)
Child Device 1 : HID-konformes Gerät
Device ID : HID\VID_16C0&PID_088B\7&85DBB8F&0&0000
Class : HIDClass
---------------- Connection Information ---------------
Connection Index : 0x04 (4)
Connection Status : 0x01 (DeviceConnected)
Current Config Value : 0x01
Device Address : 0x01 (1)
Is Hub : 0x00 (no)
Number Of Open Pipes : 0x02 (2)
Device Bus Speed : 0x01 (Full-Speed)
Pipe0ScheduleOffset : 0x00 (0)
Pipe1ScheduleOffset : 0x00 (0)
------------------ Device Descriptor ------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x110 (USB Version 1.10)
bDeviceClass : 0x00 (defined by the interface descriptors)
bDeviceSubClass : 0x00
bDeviceProtocol : 0x00
bMaxPacketSize0 : 0x08 (8 bytes)
idVendor : 0x16C0
idProduct : 0x088B
bcdDevice : 0x0110
iManufacturer : 0x01 (String Descriptor 1)
Language 0x0409 : "Digital Enlightenment"
iProduct : 0x02 (String Descriptor 2)
Language 0x0409 : "USB DMX"
iSerialNumber : 0x03 (String Descriptor 3)
Language 0x0409 : "0000000010001117"
bNumConfigurations : 0x01
------------------ String Descriptors -----------------
------ String Descriptor 0 ------
bLength : 0x04 (4 bytes)
bDescriptorType : 0x03 (String Descriptor)
Language ID[0] : 0x0409 (English - United States)
------ String Descriptor 1 ------
bLength : 0x2C (44 bytes)
------ String Descriptor 2 ------
bLength : 0x10 (16 bytes)
------ String Descriptor 3 ------
bLength : 0x22 (34 bytes)
---------------- Configuration Descriptor -----------------
bLength : 0x09 (9 bytes)
bDescriptorType : 0x02 (Configuration Descriptor)
wTotalLength : 0x0029 (41 bytes)
bNumInterfaces : 0x01
bConfigurationValue : 0x01
iConfiguration : 0x00 (No String Descriptor)
bmAttributes : 0x80
D7: Reserved, set 1 : 0x01
D6: Self Powered : 0x00 (no)
D5: Remote Wakeup : 0x00 (no)
D4..0: Reserved, set 0 : 0x00
MaxPower : 0x64 (200 mA)
---------------- Interface Descriptor -----------------
bDescriptorType : 0x04 (Interface Descriptor)
bInterfaceNumber : 0x00
bAlternateSetting : 0x00
bNumEndpoints : 0x02 (2 Endpoints)
bInterfaceClass : 0x03 (HID - Human Interface Device)
bInterfaceSubClass : 0x00 (None)
bInterfaceProtocol : 0x00 (None)
iInterface : 0x00 (No String Descriptor)
------------------- HID Descriptor --------------------
bDescriptorType : 0x21 (HID Descriptor)
bcdHID : 0x0110 (HID Version 1.10)
bCountryCode : 0x00 (00 = not localized)
bNumDescriptors : 0x01
Descriptor 1:
bDescriptorType : 0x22 (Class=Report)
wDescriptorLength : 0x0024 (36 bytes)
06 A0 FF Usage Page (unk)
09 A5 Usage (0xA5)
A1 01 Collection (Application)
09 A6 Usage (0xA6)
09 A7 Usage (0xA7)
15 00 Logical Minimum (0)
25 FF Logical Maximum (-1)
75 08 Report Size (8)
95 21 Report Count (33)
82 22 01 Input (Var, PrefState, BuffBytes)
09 A9 Usage (0xA9)
92 22 01 Output (Var, PrefState, BuffBytes)
C0 End Collection
----------------- Endpoint Descriptor -----------------
bLength : 0x07 (7 bytes)
bDescriptorType : 0x05 (Endpoint Descriptor)
bEndpointAddress : 0x81 (Direction=IN EndpointID=1)
bmAttributes : 0x03 (TransferType=Interrupt)
wMaxPacketSize : 0x0021 (33 bytes)
bInterval : 0x01 (1 ms)
bEndpointAddress : 0x02 (Direction=OUT EndpointID=2)
=========================== USB Port1 ===========================
Port Chain : 3-1-1
Properties : 0x01
IsUserConnectable : yes
PortIsDebugCapable : no
PortHasMultiCompanions : no
Device Path : \\.\usb#vid_16c0&pid_088b#0000000010001117#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0015 (GUID_DEVCLASS_HIDCLASS)
Driver : C:\Windows\System32\drivers\hidusb.sys (Version: 10.0.10586.0 Date: 2015-10-30)
Class : HIDClass
Service : HidUsb
Enumerator : USB
Location Info : Port_#0001.Hub_#0005
Problem Code : 0
Power State : D0 (supported: D0, D3, wake from D0)
Connection Index : 0x01 (1)
Device Address : 0x06 (6)
Is Hub : 0x00 (no)
--------------- Connection Information V2 -------------
SupportedUsbProtocols : 0x03
Usb110 : 1 (yes)
Usb200 : 1 (yes)
Usb300 : 0 (no)
ReservedMBZ : 0x00
Flags : 0x00
DevIsOpAtSsOrHigher : 0 (Is not operating at SuperSpeed or higher)
DevIsSsCapOrHigher : 0 (Is not SuperSpeed capable or higher)
DevIsOpAtSsPlusOrHigher : 0 (Is not operating at SuperSpeedPlus or higher)
DevIsSsPlusCapOrHigher : 0 (Is not SuperSpeedPlus capable or higher)
ReservedMBZ : 0x00
idVendor : 0x16C0
idProduct : 0x088B
bcdDevice : 0x0110
bmAttributes : 0x80
Descriptor 1:
09 A5 Usage (0xA5)
09 A6 Usage (0xA6)
09 A7 Usage (0xA7)
09 A9 Usage (0xA9)
C0 End Collection
Regards Martin
Disclaimer: I don't have any HID device available and I don't know anything about FX5.
1. https://fx5.de/ contains this message:
2. only commits relevant to HID are these:
- https://github.com/mcallegari/qlcplus/c ... a0407861a2
- https://github.com/mcallegari/qlcplus/c ... 29a0ec499f
So it may be related to hotplug (this is supported by Fendo's comment "All is working fine until i plug in another USB device.")
3. HID API has some changes in git repo, not released yet. It may be useful to integrate them.
I think you all guys are from Germany, but for others it says that for win8.1 and 10 do the following: connect the device, run installer, and replug the device.Windows 8.1 und Windows 10: Wenn Sie Windows 8.1 oder Windows 10 benutzen, schließen Sie das Interface bitte zunächst an, starten den FX5-Installer und klicken auf "Installieren". Danach trennen Sie das Interface noch einmal vom Computer und schließen es erneut an. Danach ist das Gerät einsatzbereit.
- Real Name: Peter
Hey,
the DIY FX5 have the same Firmware as the normal FX5. Same components and so on. So there is no different between them.
I also testet the Nodle U1 from DMXControl Project. (Which is based on the FX5) Its absolutly the same issue.
I tested the Installer from the FX5 site. The FX5 is not detected from the Installer and no Software is installed.
- Real Name: Peter
Here is my output of the DIY FX5 and the Nodle U1 from usbtreeview.
Both Win10 64bit
DIY FX5
Nodle U1
At the moment i avoid the problem by using my secound OS Debian on my laptop. There everything is working fine
Both Win10 64bit
DIY FX5
Port Chain : 2-4
Properties : 0x01
PortConnectorIsTypeC : no
ConnectionIndex : 4
CompanionIndex : 0
CompanionHubSymLnk : USB#ROOT_HUB30#4&ffe561e&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
CompanionPortNumber : 8
Device Path : \\?\usb#vid_04b4&pid_0f1f#0000000000112013#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_04B4&PID_0F1F\0000000000112013
Hardware IDs : USB\VID_04B4&PID_0F1F&REV_0110 USB\VID_04B4&PID_0F1F
Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0005 (GUID_DEVCLASS_HIDCLASS)
Driver : C:\WINDOWS\System32\drivers\hidusb.sys (Version: 10.0.14393.82 Date: 2016-11-24)
Driver Inf : C:\WINDOWS\inf\input.inf
Class : HIDClass
Service : HidUsb
Enumerator : USB
Location Info : Port_#0004.Hub_#0003
Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(4), ACPI(_SB_)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(HSP4)
Container ID : {d296e707-beab-5de3-98d9-756c8ae6747a}
Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 0
Power State : D3 (supported: D0, D3, wake from D0)
Child Device 1 : HID-konformes, vom Hersteller definiertes Gerät
Device ID : HID\VID_04B4&PID_0F1F\6&70AAD77&2&0000
Class : HIDClass
Is Hub : 0x00 (no)
Usb110 : 1 (yes)
Usb200 : 1 (yes)
Usb300 : 0 (no)
ReservedMBZ : 0x00
Flags : 0x00
ReservedMBZ : 0x00
idVendor : 0x04B4 (Cypress Semiconductor)
idProduct : 0x0F1F
bcdDevice : 0x0110
bmAttributes : 0x80
Descriptor 1:
Error reading descriptor : ERROR_GEN_FAILURE
Port Chain : 2-4
Properties : 0x01
ConnectionIndex : 4
CompanionIndex : 0
Device Path : \\.\usb#vid_16d0&pid_0830#5555555555555555#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_16D0&PID_0830\5555555555555555
Hardware IDs : USB\VID_16D0&PID_0830&REV_0103 USB\VID_16D0&PID_0830
Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0009 (GUID_DEVCLASS_HIDCLASS)
Class : HIDClass
Service : HidUsb
Enumerator : USB
Container ID : {2da37a04-39ed-50bb-b513-265233f139a4}
Problem Code : 0
Device ID : HID\VID_16D0&PID_0830\6&1624E9E5&1&0000
Class : HIDClass
Device Address : 0x02 (2)
Is Hub : 0x00 (no)
Usb110 : 1 (yes)
Usb200 : 1 (yes)
Usb300 : 0 (no)
ReservedMBZ : 0x00
Flags : 0x00
ReservedMBZ : 0x00
idVendor : 0x16D0
idProduct : 0x0830
bcdDevice : 0x0103
Language 0x0409 : "DMXControl Projects e.V."
Language 0x0409 : "Nodle U1"
Language 0x0409 : "5555555555555555"
bLength : 0x32 (50 bytes)
bmAttributes : 0x80
Descriptor 1:
