Scripting systemcommand argument passed badly
iamchrislaurie
Real Name: Chris Laurie
Post by iamchrislaurie » Tue Apr 26, 2016 4:14 pm
The following command works from the command line (using Linux):
audtool set-volume $(('audtool get-volume' - 5))
I cannot get that to script. I have tried many variants of the following
systemcommand:audtool arg1:"set-volume" arg2:"$(('audtool get-volume' - 5))"
Is there some syntax trick to getting the exact line passed to the OS?
janosvitok
Real Name: Jano Svitok
Re: Scripting systemcommand argument passed badly
Post by janosvitok » Tue Apr 26, 2016 4:29 pm
Maybe you need to call bash to do the parameter expansion.
systemcommand:bash arg1: "audtool" arg2:"set-volume" arg3:"$(('audtool get-volume' - 5))"
iamchrislaurie
Post by iamchrislaurie » Tue Apr 26, 2016 4:44 pm
Thank you for the response Jano!
Unfortunately that did not work.
sbenejam
Post by sbenejam » Tue Apr 26, 2016 6:32 pm
This is a command that calls a python test script that I use: systemcommand:python-script.py arg:dspdfviewer arg:P
Maybe it could help.
plugz
Real Name: David
Post by plugz » Tue Apr 26, 2016 6:59 pm
Try this one:
systemcommand:bash arg1:"-c" arg2:"audtool set-volume $(($(audtool get-volume) - 5))"
Post by mcallegari » Wed Apr 27, 2016 8:46 am
I have written an example in the documentation, so where did you guys read arg1, arg2, etc ?
http://www.qlcplus.org/docs/scripteditor.html
systemcommand:/usr/bin/vlc arg:-f arg:/home/user/video.mp4 // plays my video with VLC in fullscreen
most likely this is what you want
systemcommand:audtool arg:set-volume arg:"$(('audtool get-volume' - 5))"
By the way, this looks more like a usage question rather than a issue report...
plugz
Real Name: David
Post by plugz » Wed Apr 27, 2016 9:25 am
mcallegari wrote:I have written an example in the documentation, so where did you guys read arg1, arg2, etc ?
You're right, arg1 arg2 etc is useless.
But it works. You can also replace "arg" with "hi" or "hello", it will work too. Should a github issue be opened for this ?
This does not work, because
$((`audtool get-volume`))
is something that has to be interpreted by bash. QLC+ does not run processes through bash commands. Also, I think the simple quote around
audtool get-volume
are a miscopy, they should be backquotes. But this is another issue.
Maybe.
Please try this one:
systemcommand:bash arg:-c arg:"audtool set-volume $(($(audtool get-volume) - 5))"
Post by mcallegari » Wed Apr 27, 2016 9:36 am
Ugh...yes please
Then have a look at #843 please :)
Right. I'm wondering if the QProcess class can actually work like a proper shell. I'll check the docs when I have some time
plugz
Real Name: David
Post by plugz » Wed Apr 27, 2016 9:52 am
mcallegari wrote: Right. I'm wondering if the QProcess class can actually work like a proper shell. I'll check the docs when I have some time
No it can't. It's not a shell command interpreter. It simply runs a process.
And I think it's fine like this. Users can still use "bash -c" to run shell commands. Or even write the script in an external .sh file.
Post by mcallegari » Wed Apr 27, 2016 9:52 am
Actually, you can pass the system environment to it:
http://doc.qt.io/qt-5/qprocess.html#set ... nvironment
In any case I agree regarding a shell script.
I would do something like
setVolume.sh 5
setVolume.sh -5
