Use mp3 as input
MontyZuma
Real Name: Klaus Muth
Use mp3 as input
Post by MontyZuma » Sun Apr 02, 2017 6:00 pm
Hi!
I'm trying to test the Audio trigger functionality. Since I have no audio input at the moment I would like to use an mp3 recording as input.
Is there any way to do that?
klaus
janosvitok
Real Name: Jano Svitok
Re: Use mp3 as input
Post by janosvitok » Sun Apr 02, 2017 7:27 pm
Depends on the OS you use.
Linux: check out alsa loopback device. Start player with output to loopback, set QLC+ to use alsa loopback as input.
OSX: I assume Core Audio has similar facility
Windows: It may be possible to instruct QLC+ to use the overall mix as input. In that case, you need to start normal player.
MontyZuma
Post by MontyZuma » Mon Apr 03, 2017 5:24 am
I'm posting in Linux specific - it's safe to assume I'm on Linux. :D
But I very much appreciate this full answer - I'll get some info about alsa loopback devices. I might report back my experiences.
klaus
janosvitok
Post by janosvitok » Mon Apr 03, 2017 8:54 am
Sorry, I didn't notice the forum :)
MontyZuma
Post by MontyZuma » Mon Apr 03, 2017 9:05 am
Solution for Ubuntu/PulseAudio:
  1. Install pavucontrol
    sudo apt install pavucontrol
  2. Open a shell and load the PulseAudio loopback module:
    pactl load-module module-loopback
  3. Start qlc+ and use audio standard input, add an audio control and start up the whole stuff
  4. Start audio playback
  5. Start pavucontrol and in the Record Tab find ALSA Plug-In qlcplus and select Monitor of internal Audio
    Beware: qlc+ only shows up in the Record Tab of pavucontrol, when the Audio Trigger is switched on!
YMMV - Works for me. (Sorry for the Screenshot in German)
The right keyword for your own search: pulseaudio loopback or alsa loopback.
Post by mcallegari » Mon Apr 03, 2017 9:13 am
Thanks for sharing :thumbsup:
MontyZuma
Post by MontyZuma » Tue Apr 04, 2017 11:01 am
  1. Open a shell and load the PulseAudio loopback module:
It's possible to add the module in the system-wide config file: /etc/pulse/defauld.pa so you don't have to use a shell every time you want to use a mp3 as an audio input.
