QLC+ 4.10.4 - openSUSE Build Service - no ola plugin?
slight
Real Name: Stefan Krüger
Hello Forum,
i have installed QLC+ 4.10.4 with openSUSE Build Service option on my Kubuntu 16.04 64bit system.
I have ola installed as selfcompiled gitversion.
if i start qlc+ i don't see a ola plugin. in the ReleaseNotes it says
[quote="mcallegari"]
Now a few deployment updates:
  • Every Linux build now includes the OLA plugin, but OLA is not a hard dependency of the package. The plugin will be listed in the IO manager only if OLA is actually installed in the system.
is this also true for the obs versions?
how can i check if the ola plugin is included?
Actually the OLA plugin is not present in the OBS xubuntu packages.
However, it is in the official packages
slight
hi mcallegari,
thanks for clarifying this.
i deinstalled the obs version
sudo apt-get remove qlcplus-qt5
and installed from the deb
sudo dpkg -i qlcplus_4.10.4_amd64.deb
then if i run
stefan@stefan-latitude:~$ qlcplus
Q Light Controller Plus version 4.10.4
This program is licensed under the terms of the Apache 2.0 license.
Copyright (c) Heikki Junnila (hjunnila@users.sf.net)
Copyright (c) Massimo Callegari (massimocallegari@yahoo.it)
qlcplus: symbol lookup error: /usr/lib/x86_64-linux-gnu/qt4/plugins/qlcplus/libolaio.so: undefined symbol: _ZN3ola10StringTrimEPSs
there is a error and it will not start.
i have looked at the commandline options but there seems to be no 'verbose logging' or something similar..
how can i debug this?
which OLA version ?
That's clearly a binary incompatibility issue
slight
it is self compiled form git (last update about 2016-11-02)
stefan@stefan-latitude:~$ olad -v
OLA olad version: 0.10.2
iam on a Kubuntu 16.04 64bit system.
DJefke
Real Name: Christophe Van Reeth
I encounter the same issue with the latest QLC+ version.
djefke@homer:~$ qlcplus
Q Light Controller Plus version 4.10.5b
*** Error in `qlcplus': malloc(): memory corruption: 0x00000000021bfdf0 ***
Aborted
djefke@homer:~$
OLA version: 0.9.1-1.1 (package from official Debian repository)
OS version: Debian Jessie 64bit
QLC+ is the .deb package from the QLC+ download page.
It's not really a big issue for me at this moment. But I just wanted to report it :)
Again, that's most likely a binary incompatibility.
I have no idea why Jessie has been kept back to OLA 0.9.1, but that's a pretty outdated version and I normally build with OLA 0.10.x
Have a go with the OBS versions here: http://software.opensuse.org/download.h ... ackage=ola
Or download each OLA package starting from here: http://download.opensuse.org/repositori ... llegari79/
